Skip to main content
Technical specification
Last updated: June 10, 2025 05:05. Revision #10014
Continuous power output:
  • 2 x 70W RMS into 8 Ohms
  • 2 x 125W RMS into 4 Ohms
  • 1 x 250W RMS into 8 Ohms (Mono)
THD (unweighted):
  • <0.015% @ 5W/8ohm
Frequency Response:
  • 10Hz - 30kHz (-1dB)
S/N ratio (ref 1W into 8 Ohm):
  • >110dB (20-20k bw)
Crosstalk @ 1kHz:
  • <-82dB
Inputs:
  • Balanced, Unbalanced.
  • 12v Trigger
Input sensitivity:
  • 3.6V (mono XLR), 1.65V (mono RCA), 0.9V (stereo RCA), 1.9V (stereo XLR)
Outputs:
  • Speakers, 12v Trigger Loop out
Max power consumption:
  • 300W
Standby power consumption:
  • <0.5W
Dimensions:
  • 56 x 215 x 215mm
Weight:
  • 1.65kg
